pir query | on ElectriciansForums
Discuss pir query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
woodsta
i am carrying out a report at a local bar and i see it has a split load board, is this still ok with current regs or should i suggest upgrading so everything is rcd covered
if it was installed to the 16th ed then dependant on what circuits are rcd protected, and no real defects can be found it was good enough then it is still now. only if you work on or alter circuits do they need to be to 17th.
There is also the fact, that as it is a place of work, then RCD protection for socket-outlets is not required, except for those used for mobile equipment outdoors, or those intended to be used by customers.
Reply to pir query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would put this down to 433.3.1(ii) - no overload protection needed because the load at the single socket can't overload the cable, being fused...
