J
justjust1
Hi all,
as said in my previous post i am a trainee sparky @ collage doing some work on my extension @ home i have passed my level 2 city and guilds, and am starting 3 next wk.
I have a question! In my garage i have an existing lighting circuit i want to add a PIR sensor with an isolation switch for my outside lighting. When drawing my wiring diagram i got stuck!!!! I want to use Twin and earth because i can tack it directly to the wall but am now stuck with the neutral!!!
If i take the live feed down into the switch then into the PIR thats fine. But then i end up with one (on its own not in gray cable) neutral traveling from the feed into the PIR!!!!!! Hence not looking nice!!!! Am i going to have to wire it with single cable? or can i take the neutral down into the switch and join it with a connector block and send it back up to the PIR using a FCU?
I know this is a possibly a stupid question but am still learning!
