schoe
Hi all im connecting 2 lights with internal built in pir sensors. I have run a 1.5mm t&e from a switched fuse to the first light connecting to L N E, i then looped the second light with built in sensor the same way. When i livened up the circuit the first light came on and went off, but the second stayed on.
Do i need to use 3 core and earth and link the L on light one to the L2 switched live on light 2 to meke the both lights come on and go off at the same time.
Thanks Chris
Thanks Chris
