G
Goldygoldy
Hello all
i installed some post and spike lighting for a client switched via a 360 degree PIR controlled by an outdoor light switch
now the clients wants to be able to flick a switch so his outside lights can over ride the sensor and remain illuminated until he switches them off
then to be able to flick a switch if he wants the lights to illuminate by the pir
I have ran a permenantt feed to the pir from the switch and then switch wire from the pir to the lights
thanks in asvance
thanks in asvance
