A
Alexl_82
Hi guys, looking for some help and advice and wondered if any of you guys can give me some which would be much appreciated.
Im replacing switches in a stairwell in a block of flats for 2 wire PIR switches that dont need a neutral. I have replaced the switches that were simple push to make a circuit switches that controlled a timer under the stairs which in turn controlled the lights. Ive done away with the timer as the PIR switches each have their own timer built in. Now the problem is this, the lights all switch on ok but when the PIR switches have deactivated some of the lights flash. With my test lamps I can see that the voltage is fluctuating between about 40v and 150v across the switch live even though the PIR switches have not been activated. The lights are 28w2d and there are around 10 - 15. and there are about 6 of my new PIR switches all wired in parellel.
Im wondering if i Need to wire in a capacitor to fix this and if so would just 1 be ok? Also what size would i need?
Really hope someone can help with this.
Many thanks in advance,
Alex
Alex
