A
AD 543
i did a test on a property, found lighting circuit wired in 1.5 2 core T&E, no cpc. Under the 17th edition this circuit would need a cpc. On the PIR form
I filled in requirement 2 - needs attention. does this then need to be changed, immediately? Or can i state to the customer it is acceptable provided no changes are made to the light switches and fittings?
Are we obliged to ensure if we have done a test that must be 17th edition compliant?
