A
andekoch
When I do a CU change on th einstallation cert I clearly state that it is only the CU that was changed blah blah.
Although before I take out the old board I do a full PIR to make sure there are no surprises when the board is changed. Of late I have been scheduling my PIR's a week befor ethe board change to allow me to plan for code 1 and 2 repairs before the new board is signed off.
I was wondering how long I can reasonable leave it between the PIR and the CU change before I retest everything in full at the CU change. All I do in the CU change at the moment is insul resistance between line and neutral connected together and earth and take the remaining R1 + R2 etc from the PIR (or repairs) I did the previous week.
Do you recon this is acceptable?
