Pir | on ElectriciansForums
Discuss Pir in the Australia area at ElectriciansForums.net
I have just changed some old 600 x 600 units over to spots with LED GU10's in some toilets and the spots flick on and off when they should be off. the switches are old PIR type with a battery in them. i have put a temp switch on one and it works fine but the client wants to keep old stuff. Help!
The most likely cause of this behavior are:
1) Light spill from one or of the LED lamp is triggering the PIR, due to the wide spectrum of some LED sources extending into the infra-red.
2) The PIR incorporates a dawn-dusk sensor which is being triggered by one or more of the lamps.
Solutions include:
1a) Shielding the PIR sensor from extraneous light spill.
1b) Re-site the PIR sensor to avoid the extraneous light spill.
2a) Modify the dawn-dusk sensors threshold to prevent triggering.
2b) Bridge-out the dawn-dusk sensor to prevent triggering.
thanks markie
i changed the leds to normal gu10's and they work fine. i have talked to a few people about this and it seems that the aurora led is not compatible with the switch type that is on there.
Reply to Pir in the Australia area at ElectriciansForums.net
That will work fine as long as the Pirs use relay switching, some don't.
I've a few flush pirs fitted around the house Hallways , Kitchen , Toilet etc One of the best things I ever did The pir integrated into the...
