PIRs | on ElectriciansForums
Discuss PIRs in the Australia area at ElectriciansForums.net
F
Fitzelectrics
I am a newly qualified electrician and have been asked to do all the periodic inspection and testing for a retail chain, although i'm 17th edition, part P and 2392 inspection and testing qualified do i need to be NICEIC, ELECSA etc registered to undertake this work if not is there anything i should be aware of before i get started
Any advise would be greatful
its a good idea to do so mate. good luck, and i hope you learn a lot. theres no shame in admitting that your not so clued up on a certain area, or you lack experience. its far better that you admit so, and rectify the problem by getting somebody else to do the PIR, with you working alongside. A) you wont have any liablility and B) you get experience.
I totally agree, I wish i knew it all it would be much easier and cost affective for me, you cant beat blunt and honest answers thanks again
there will be alot more advice i'll be looking for so watch this space
by asking the question your on the right track as Spinny says no need to be registered Although a lot of clients want this
more importantly you have adited You dont feel up to it and by pairing up you will gain experience and see some of the things they Dont,Cant teach you there are thingssome guys see day in day out You may never see but when you do come across some OLD stuff have a good look at it for missing parts ect
Every day is a school day
Hi Guys
selling my house, surveyor said that all the circuits in my loft have to be above the insulation, surely thats only new builds, my house is only 20 years old however it will have a full IR test, any comments ?
Circuits don't necessarily have to be above insulation.
However, they have to be sized appropriately to account for the current de-rating, that being under the insulation will cause.
If you have 2.5mm² RFC cables under insulation that exceeds 100mm, then either they should be changed to larger cables, or they should be above the insulation.
Wouldn't normaly matter with lighting cables.
Reply to PIRs in the Australia area at ElectriciansForums.net
Hello - Did you get your problem sorted?
Hello Dave, Thanks for taking the time to reply. I appreciate the info, I haven't updated this post yet, but I have since been talking to some...
