Hi all
I am new to this trade and just wanted to know a few things. With regards to PIR's.. as i understand it its wired like a 2 way switch? As in you have your feed from the board to your first PIR, then from there a 3 core between all PIR's and from that same point you loop to all the lighting points..is that correct?
Also with non-maintained em lighting..do you just run a circuit out of each lighting point to the em position as in keep it on the same circuit?
Not very specific i know but i hope it makes sence
Much appreciated
Much appreciated
