Plasplugs wet tile cutter - it sucked!
I recently borrowed a plasplugs wet tile cutter from a friend to cut some floor tiles. In his opinion this was a pukka bit of kit, easy to use etc, he did not have a bad word to say. I cut a few tiles with it but had real problems. Here is how it went...
Tried to cut the tiles by sliding them along a fixed straight edge to get things dead straight but this did not seem to work. The cut seemed to have a mind of its own and I just could not get a straight cut. The cut seemed to wander off my pencil line with an ever increasing error as I cut further into the tile. I then noticed that the guide behind the cutting wheel (also holds the blade guard) was not exactly in line with the cutting wheel. I sorted this out but the tiles still did not cut straight, exactly the same problem as before. I then tried cutting without the straight edge and also without the guard but still no way to get a straight cut. I can only guess that the cutting wheel is somehow not quite straight.
Maybe this plasplugs tile cutter is past its best, but then just maybe the plasplugs products sucks!
Steve
Plasplugs wet tile cutter - it sucked! for the Original Article on Tiling Advice Forum
Steve
