B
bontjack
I intend replacing a pendant light fitting with a new light and fan unit (heavy weight), however the screws of the pendant were only fixed into plasterboard and not into the joist because the wiring exited the plasterboard in between the two joists.
The plasterboard is not going to support the weight of the new light fitting even with the expanding raw plugs..
What is the best solution for fixing the heavy light fitting at this point, as I cannot repoisition the wiring over to the joist as the ceiling is artexed.
Any ideas, solutions that i could use or try?
