Plasterboard depth of back boxes | on ElectriciansForums
Discuss Plasterboard depth of back boxes in the UK Electrical Forum area at ElectriciansForums.net
vini
Glasgow, East End
Just had a discussion with a builder where he told me that metal back boxes have to be fixed at a certain depth. The front edge of the box should be about 3mm depth from the front surface of plasterboard (12mm). I am unaware of any depth requirements regarding plasterboard and metal back boxes, height requirements yes and distance from corners etc. but it is a new one on me as to depth. He did not want fast fix boxes, in case they came out even though the wall was being tiled after the first fix.
Am I missing something or am I dealing with a smart ****?
tell the builder you have long screws!
the front edge of the box should be just below surface, but there's no stipulated figure. i suppose his reasoning ( if a builder has any) is that the metal box would contain any arcing.
Flob-a-Dob-a-Dob.
[ElectriciansForums.net] Plasterboard depth of back boxes
It was the 3mm that got me. It is plaster board on a wooden frame and he was placing dwangs across the studs for me to fix my boxes onto. To me there is a good practice rule rather than a precision rule
on any timber frames ,I stick my own noggins for my knock out boxes .
Reply to Plasterboard depth of back boxes in the UK Electrical Forum area at ElectriciansForums.net
