Plastered Ceiling | on ElectriciansForums
Discuss Plastered Ceiling in the UK Electrical Forum area at ElectriciansForums.net
london
Hi - I have just had ceiling plastered - I have never cut holes in plaster before but am not to bad on diy. The ceiling was overboarded so I have cut bigger holes out of the lath plaster and measured with laser. I can also access from ceiling.
I want to know if I drill from the loft downwards to make a pilot hole is that ok to do - then I planned to buy one of those hole cutters. I do not have a speed controlled drill and the teeth on the hole cutters I have seen look really jagged - will they not wreck the plaster? When I look it up on line all the videos are cutting holes using these tools are on non plastered ceilings and just plain old plasterboard. What happens if I use a whole cutter on my drill with the ceiling plastered?
I am thinking of doing the holes with either this:
or one of these (but the teeth look like they would shred the plaster.... has anyone experience of using these on a plastered ceiling please?)
Which would you recommend?
Any advice appreciated - just nervous to cut the holes!
Thanks,
Arun
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
I must get me one of those dadddddddeeeee dust contraptions
I currently use one of those plastic covid face shields ?
heavily tinted of course. woudn't like to frighten female sparks from the trade. ??
Are you telling me you can get a tinted version ?
yep. ask any tanning salon out of the hundreds you got down there.
under 35, blonde. 35 -55, middle brown, over 55 grey. no problem.
Reply to Plastered Ceiling in the UK Electrical Forum area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
