Plasterers no good, cut the wrong sized hole for your switch ? | on ElectriciansForums
Discuss Plasterers no good, cut the wrong sized hole for your switch ? in the UK Electrical Forum area at ElectriciansForums.net
No need for a mistake plate in that case ED:p
No worries Pete, I've found one that'll do the job.
[ElectriciansForums.net] Plasterers no good, cut the wrong sized hole for your switch ?
I had a look on the Screwfix and Toolstation websites to see if I could get hold of some 1-gang and 2-gang Electrical Cover Mistake Plates, but neither had any in stock. Typical. I'll give CEF a ring on Monday to see if they can order me some.:)
Taking a chance JK get a firm price first
Reply to Plasterers no good, cut the wrong sized hole for your switch ? in the UK Electrical Forum area at ElectriciansForums.net
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
Yes, the entire socket front needs replacing. it is a fairly straightforward task for someone with some experience of DIY electrical work. if it...
