Plastic amendment 3 CU's | Page 4 | on ElectriciansForums
Discuss Plastic amendment 3 CU's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello mate, The CU you have used would not be compliant. Needs non combustible cover and blanks see here for Wylex offering; http://www.electrium.co.uk/Wylex_Metal.pdf
Thanks for the info fella. The DB in the picture has a metal hinged lid on it out of shot. If the blanking covers need to be metal then so do the MCBs, RCDs and main switch!
if the lid is clossed its not classed as external so it complies acording to leaflet
I hope so. According to Hager it does so I'm happy! I get the feeling that I won't fit another one til January, I think other clients will opt for insulated til then. Not 100% as to whether the rubber insert on the tails gland complies though! Will have to read up.
These are good, but bloody expensive at the moment. The price of a new consumer unit keeps on rising, making the domestic market even more fun to get work because the consumer is only concerned with price.
I can get a fully populated wylex dual RCD amendment 3 board for ÂŁ106 plus the above gland for ÂŁ11 including VAT, so just shy of ÂŁ120 which I don't think is to bad tbh.
I wonder if the likes of B&Q, Screwfix etc will replace their best selling ÂŁ50 fully populated high integrity CU's with metal by Jan 2016? Seems unlikely.
I think I'll just hang fire until the 11th hour and see what progression is made.
All seems like over the top nonsense to me at the moment, particularly as non ferrous metal boards have only been suggested as an example.
Unfortunately, existing boards can only claim fire retardency or self-extinguishing characteristics according to the standards; they are combustible according to the 960 °C glow wire test. It is only when the source of heat is removed that they self-extinguish and thus pass the standard by the 'alternative' criteria which enabled the use of thermoplastic enclosures in the first place.
Why would they? They can still be installed in commercial premises and also bear in mind there are still muppets around installing single up front RCD units or 16th ed boards!
And there are still muppets installing CU's without doing any testing :-( Just been to quote for some minor works at a property. 10 months ago I lost out on the board change and some other work. Householder showed me the "certificate".
They have both the top copy and the carbon one. No serial number, no contractor address, no schedule of test results at all. And gems such as "means of earthing : rod by front door. Ra N/A" No PFC, No Ze. Illegible scrawl for design. Illegible scrawl for construction, no signature for I&T. Lost the will to live before I got half way through the schedule of inspections. There's a 16mm T&E sub-main (hopefully) crimped and taped hanging in free air about a foot away from the new board, which has missing blanks and exposed bus-bar.
So yes, B&Q will probably carry on selling their ÂŁ50 specials. It is not their responsibility to ensure the correct installation. In the same way that they can sell bricks, sand and cement which some cowboy can use to build a 6 feet high 1/2 brick retaining wall.
Edit. They were happy with the cert - they had some paperwork so must be OK. Joe Public, even if they know they should have a cert, have no interest, or clue, about what information it should contain.
And their "electrician" is registered with a scheme.
Managed to get the glands for ÂŁ13.00 each through a mate in wholesale. I think some customers will be happy to pay the extra for increased piece of mind. I am less averse to metal clad than I was a few weeks back. Might even change my signature haha!!
Earlier on when I first read these threads , I was like others thinking about other options available rather than the knee jerk reaction to insist on steel enclosures and one idea I mentioned which has never come up again was the suggestion of fitting intumescent material of the same type as used on fire rated downlights into CU's as a way of containing any flames should a fire occur.
I know you can buy this material for use in sockets and other enclosures, so if it's good enough for the downlights then why not CU'S? ??
Surely something along these lines would be better than what is being implemented, as steel CU's can still have fires caused by poor workmanship ,also just look at any existing ones they've usually got several openings where knockouts weren't blanked off, by lazy or incompetent people this will continue to happen!
The root cause is poor workmanship and that is the issue that should have been tackled first !
But Imo the same shoddy installers will carry on and there will be CU fires and probably a few deaths or injuries from electric shock from people touching live casings!
And by the time someone wires a 10.8kW shower as well as a cooker etc into one of these monstrosities, it'll be so well sealed that the heat build up within will just have nowhere to go....
I think now that am3 is going to happen with regard to non combustable cu's (or cupbords very unlkkely to happen) lets as a trade embrace this as it is whats happening so get on with it.! I dont think fitting a M/C cu to a competant spark is beyond any1 worth theyre compentance.! I personally like yhe idea or M/C cu's in domestic, fed up of seeing swa poorly terminated and plastic cracked, flimsly din rails.! Feedback from alot of my customers (domestic) as non rlectrically minded people say they see a metal board as stirtidier more durable and safer and have no problem with the extra.! My opinion, im sure its not every1's tho ;)
The issue isn't the competant installers being capable, after all, most competant electricians will have fitted a MC 3 phase board......
Its the incompetants who cause these problems! !!
Only today I had to connect a new boiler supply into a dual RCD unit fitted less than two years ago, [no certificate anywhere and it was rough as rats inside, neutrals and CPC,s not in the right order and the incoming tails were loose ! Sadly the enclosure material won't do anything about this kind of thing.
Reply to Plastic amendment 3 CU's in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ah my mistake - apologies. I have something more or less like this wylex unit and the flappy plastic cover has got a broken pin so won't stay one...
  • Duplicate posts
    Any suggestions for avoiding the duplicate posts that keep happening? I'm trying to delete mine...
  • Duplicate posts
  • Borrowed earth
    I don't think Westward is suggesting the existing cpc is 4mm. He is saying the new earth pinched...
