View the thread, titled "Plastic hot water connection. Which compound to use??" which is posted in Plumbers Forums on Electricians Forums.
Hi, I have a leak on the hot water inlet of my concealed Aqualisa Gainsborough shower.
I have stripped it back and with the hot water feed on I can see the drip appear at the bottom of the plastic screw fitting.
I want to ensure that when I re-tile it, I won't have the same problem in the future and was wondering what to use around the plastic thread to make a well sealed connection, (PTFE, boss white, etc etc) bearing in mind it is the hot feed of a plastic/nylon inlet.
(I have attached a photo and the leak is appearing on the screw nut with the red dots)
Many Thanks for any advice.
Continue reading...
Reply to the thread, titled "Plastic hot water connection. Which compound to use??" which is posted in Plumbers Forums on Electricians Forums.
