plastic mounting box and metal switch | on ElectriciansForums
Discuss plastic mounting box and metal switch in the Talk Electrician area at ElectriciansForums.net
T
tomrus
I have a couple of dry lining mounting box (plastic back box), and I want to put a chrome switch plate, can I connect the earth directly to the faceplate of the chrome switch or I also need to replace the mounting box with a metal one?
thanks
Tom
Just connect the earth to the faceplate...you should test to ensure the earth is actually an earth,they arent always...do you have the equipment to do that?
You are ok to terminate the cpc/earth to the crome face plate. You are ok using plastic wall mounted back boxes unless the back box are there for mechanical protection but won't look good with crome switches. Ps, welcome.
Are you competent to do this? We do an R2 test as a minimum in these situations, it's rather important...
i agree with iq, unless qualified/competant leave to the electricians who are, some light switches have more than 2 cables at them..........
thanks guys, I have about 20 switch to replace and electrician asked ÂŁ200+ to change all of them, I change them by myself and he's coming for testing for ÂŁ40...
sory Tom but Iv known electricians cockup 2ways and it gets even worse if theres 2,3,4 gang switches As for your spark "testing" for ÂŁ40 I wouldnt test a DIYers work but thats my opinion I dont DIY my servicing on my car to save a wee bit of money Pay the price n get it done correctly
Reply to plastic mounting box and metal switch in the Talk Electrician area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
