Plate Switch inside a bathroom! | on ElectriciansForums
Discuss Plate Switch inside a bathroom! in the UK Electrical Forum area at ElectriciansForums.net
Goody
London
Hi,
I have just come across a Plate Switch mounted on the wall inside a bathroom to operate the ceiling light. Is there any alternative fitting to replace it (to conform with the reg) without resorting to installing a pull-cord switch? Any feedback will be much appreciated. Thanks!
[ElectriciansForums.net] Plate Switch inside a bathroom!
True, but what if someone touches it with water dripping from their fingers?
That might teach them how to use a towel.
Seriously though you could say that about almost anywhere - you should have a pull switch in the bedroom in case someone goes from the bathroom to get dressed in the bedroom, pull switches in the kitchen for when you're doing the washing up etc.
You'd end up with so many pull switches it'd be like living under a barrage balloon.
If you can fit sockets in a bathroom, as long as they are 3 mts from the bath/shower, what's the problem with plate switches outside of zones?
I don't think the extra 2.4 mts will allow your fingers to dry while you walk it.
I agree that REG only stipulates use of electrical equipment in the right zone but my concern was someone getting a shock with wet fingers, should the switch developed a fault at some point.
Even toilets in schools use standard rocker switches, more often than not with no RCD protection. The bathroom/shower room regs are due to the chance of touching something with lower resistance of your body after immersion, not to guard against wet fingers. As previously said, you could exit the bathroom and switch a light on a few feet away, or come in out of the rain dripping wet and switch a hall light on.
Outside of zones you can put whatever switch YOU, as the professional, deem suitable.
Hope this clears it up.
Reply to Plate Switch inside a bathroom! in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
