PLC controlled lighting system with PIR's | on ElectriciansForums
Discuss PLC controlled lighting system with PIR's in the UK Electrical Forum area at ElectriciansForums.net
C
cherryman
hello,
I am designing a lighting system for a building using a PLC, i know how to create the programme etc.. all i need help with is how integrate the PIR to the PLC and how to inegrate the PLC output to the lights mains supply.
I am using a Mitsubishi FX1S 14MR PLC as that is what I have.
I have found a PIR with a relay output which I think should be suitable for the job.
http://www.onstatetech.com/Tech-specs/tech PMSC36 PIR occupancy sensor Rev4.pdf
Can anyone help in figuring out how to connect it all up? I understand the theory but now its come to practical I am a little lost.
Thank You
Reply to PLC controlled lighting system with PIR's in the UK Electrical Forum area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
