plc question | on ElectriciansForums
Discuss plc question in the UK Electrical Forum area at ElectriciansForums.net
Bradford
hi I was hoping to get some help with some college work the question I am on is as follows:
A machine starter motor is only allowed to run if a start signal has been received and emergency stop signal has not been received. Also there must be a signal detecting that the machines safety guard is closed and a safety feature in front of the machines working area has not detected any human presence
I was hoping to get some help with how this would be setup and the equipment used
I hope some one the time to point me in the right direction thankyou
Too many variables, each machine has a different risk assessment and criteria for safety, you plc is a second level control usually and your safety relay is primary... using an E-stop input to a plc is normally a secondary signal and not part of the safety system.
In a control system you normally have a primary safety system, then a secondary control system, your E-Stop system (primary) is usually independent but some more expensive set-ups can be used with E-stop signals directly safely shutting down control equipment like motor VSD's etc but these are more expensive normally to fit .
I don't think your question even warrants a plc with the info given, just a basic safety circuit but with no info I cant tell you anymore.
One of the trick questions with PLC’s is the inputs for stops. I think this is what they may be asking for. Otherwise as DW said a PLC would be a total waste of resources.
Without giving you the answer, you have to think the opposite of a normal stop circuit.
What switching devices? There’s far too many to choose from to give a definitive answer.
Have a rummage through the RS catalogue for each of the devices you mentioned. It will have data sheets giving the connections needed.
If it's simply a PLC exercise with no real world application you just have 4 contacts (switches) in series operating an output.
Inputs would be, start button, E stop, guard switch and presence detector, use N/C contacts for the last 3 so they would fail safe and N/O contact for the start button, the output operates the motor.
That's as simply as it get's for a classroom exercise, but as stated above it would be a LOT more complex in a real application.
This is why I mentioned the “standard trick question”.
Reply to plc question in the UK Electrical Forum area at ElectriciansForums.net
I think maybe it can be done with an arrangement of relays but need to think about the wiring ?
Thanks for this reply, this has helped!! I felt quite deflated and let down by this experience (1 bad thing wont end my hopes of being a full time...
