R
Richard3009
If you wanted to use an output of a PLC to start a DOL motor, would the PLC output power be used to energise the coil on the contactor at 110v,
Discuss PLC switching in the Commercial Electrical Advice area at ElectriciansForums.net
Richard3009;9 If you wanted to use an output of a PLC to start a DOL motor said:You can use a PLC to switch the DOL but depends on a couple of things. Firstly does your PLC output 110v and secondly could it handle the current switching.
Is your PLC a micro logic block, brick or modular?
Is the output a relay, transisor or triac?
You could also use an interposing relay which is the PLC output switching a relay to switch in the DOL contactor.
A word of warning; follow all PLC manufacturer's instructions for switching inductive loads else you could end up replacing components or the PLC itself... back up the PLC program too!
regards s.f
... I doubt the card will be 110v....
Reply to PLC switching in the Commercial Electrical Advice area at ElectriciansForums.net
