Please advise me on safety of loose plug | on ElectriciansForums
Discuss Please advise me on safety of loose plug in the UK Electrical Forum area at ElectriciansForums.net
Stephi
Birmingham
Hi, I'm not an electrician or anything of the sort but I'm hoping to just get some quick advice. In moving my bed I accidentally somehow pulled the faceplate of a plug socket loose so now it's at an angle.
[ElectriciansForums.net] Please advise me on safety of loose plug
I won't be able to get in touch with my landlord until the morning so I'm hoping someone can advise me as to wether it's safe or if I should turn everything off at the fuse box for the night.
Apologies if I'm in the wrong place and thanks.
Just try not to touch it until your landlord fixes it should be a simple task of just screwing it back, unless of course you have broken the fixing lug off in the back box , either way a simple repair, don't let your landlord fob you off with a hike up price. No nee to switch your fuse box off. Just leave it alone the Electrician should be able to fix that in 30mins max
The socket will need to be replaced as you have broken the part that the screw holds in the socket front and it is potentially dangerous until that is done. When I say dangerous, I mean if anything touched the live parts in the now exposed back of the socket, well I am sure you understand what might happen. Just (as stated above) give it a wide berth.
Thanks everyone, my landlord's handyman is coming over later to check it out and fix it, probably an overreaction on my part but I was worried about it starting a fire or something. Thanks again for the help!
Looks like it has been unscrewed and left loose to me. No wonder it moved when you caught it.
As above, let landlord know and don't touch it. Have you got kids or pets in the house?
Reply to Please advise me on safety of loose plug in the UK Electrical Forum area at ElectriciansForums.net
Maybe the track itself is live, are they metal units, I'd be getting it tested properly
I well remember the sliding windows on ther Mini, and also the manual choke and the foot-operated dip switch. I recently traded in my 18 year old...
    • Informative
