please check my calculations | on ElectriciansForums
Discuss please check my calculations in the Australia area at ElectriciansForums.net
damien1
hi guys i did my 17th edition in 2008 and ive not done much in the trade since then ide be most gratfull if someone would please check my calculations
1 cooker hob rated at 5.7 kw
1 oven rated at 4.8 kw
so total is 10.5 kw / by 230v gives me 45 amps
after doing the diversity calculation i come up with 20 amps so would i be right in thinking to put a 32 amp breaker in or could i use the existing 40 amp breaker all im doing is moving the existing cooker radial
and im using 10mm cable
thanks for your help guys
Reply to please check my calculations in the Australia area at ElectriciansForums.net
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
