Good evening all. I'm in desperate need in some help please. I recently changed a fuse board with a horstmann radio telemeter series 2a NU077-222, not realising that it is an economy 7 meter.
I'm very confused into the connections of the other tails required to feed a separate fuse board for the economy circuits.
They have also had a new water heater fitted so does that also need to go onto the night rate economy 7 Fues board to as well as the storage heaters.
Any information will be so helpful thank you.
kind regards Dale
kind regards Dale
