Please help me to get the answer. | on ElectriciansForums
Discuss Please help me to get the answer. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
turbomen
A special LED has a forward voltage of 2.2 V, and requires 10mA to produce its rated output. It is to be powered using a 9 V battery:
a. Calculate the value of the LED’s series current-limiting resistor
b. Calculate the exact power supplied by the battery in mW
c. Calculate the power dissipated by the LED in mW
d. Calculate the power dissipated (heat) by the resistor in mW
r=v/i ,
r=6.8/0.01
p=i*v
p=0.01*9
p=i*v
p=0.01*2.2
is the difference between power supplied by battery and power used by LED
Homework for tomorrow?:)
Upvote 0
Hmmm i answered 4 parts and corrected others and didn't even get a thanks, i'm not going to play any more:p ;)
TBH Turbomen you should have a go yourself and then ask if you have got the right answer or are on the right track. That way you will learn much more than just someone taking you straight to the right answer:)
Upvote 0
Do you not have course notes to revise from???
I have some course notes to revise from but they are always concentrate on the lab work.
Sorry, it is a time difference between you and me. So, I am late to give thank you.
Sorry, it is a electronics test review.
Upvote 0
Reply to Please help me to get the answer. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
As you have actually measured the cold resistance (R1 + Rn = 0.15) then you have the voltage drop at the expected current (60A) so you can compute...
Just doing some thread admin :)
Electrical Courses
