sotonjames
hi folks, i have a problem with the timer for my immersion heater, it is an old sangamo dial timer with 4 pins, 2 on and 2 off, half the dial is black and half white for day/night.
the problem is a few nights ago the dial stopped and the fuse in the main fuse box was tripped. i only realised when i had no hot water, i flipped the fuse switch back and it merrily started spinning again as it was before so i reset the time to be correct and hoped for hot water again, however it does not appear to be switching the water heater on or off.
i have tried doing ti manually but nothing seems to make the heater come on.
please help as i loathe paying npower for using the boost element.:cuss:
