please help work out driver size for led. | on ElectriciansForums
Discuss please help work out driver size for led. in the UK Electrical Forum area at ElectriciansForums.net
W
waz6986
Good evening everyone.
Im wanting to fit some leds to my aquarium. Im looking at two rows of white and one row of blue. I have found the units i would like to use 20pcs 5050 SMD 4led plastic waterproof LED injection module. 20 white poss 30 and 20 blue. Ideally i would like to be able to switch the white off on there own and the blue too. And if not to difficult sneak a dimmer in too.
So the info im desperately trying to get my head around is the driver requirement. This is the info for the modules theres 20 blocks of 4 led wired together.
Input*voltage
DC*12V
Input*current
0.08A
Input*Power
1.44w
Power*factor
>0.9
Power*efficiency
>90%
Luminous
4-6lm 12-14lm 18-20lm *per piece
Lighting*efficiency
>80%
Many thanks in advance
Gary
Back to basis:
1.44 x 20 = 28.8w. Use a 30w or 35w. I can supply these
i can also supply RGB Modules (samsung 5630 - 115lm each) at ÂŁ1.75 each.
all modules are IP68
Range of power supplies between waterproof, rain proof, metal and plastic.
dimmable options available as well
2 years warrenty
use a PSU that's made for intruder alarms systems with a battery back-up fitted. fit switches on the casing for the LED strips.
Back to basis:
2 years warrenty
Congrats on becomming a new sponsor here on EF, I hope dan isn't taking too much money off you.
Reply to please help work out driver size for led. in the UK Electrical Forum area at ElectriciansForums.net
