Hi,
I would genuinely appreciate some guidance. I am currently completing training for my City & Guilds 2391-52 practical, and as there is some time before I take the test, so I wanted to get some on hands training done at home, in safe manner. I've decided to make my own single phase training board, like the one I've used at the training centre. I am now stuck as I've hit a knowledge barrier and can't find the appropriate solution. Please see images and questions below.
This is my training board
This is how I plan on powering the training board, with a 13a fused cable
My problems start here, I plan on using a 2.5mm cable to connect to this, is this ok?
Assuming a 2.5mm cable is ok for the front side, at the rear I have another problem, as I have 16mm supply cables feeding the consumer unit. I need to step these down in size to fit the 2.5mm cables from the front. What is the correct procedure for doing this and what do I need to buy to fit and proceed?
I will also run a 2.5mm earth cable from the socket on the front side to the consumer earth bar and also run another 10mm earthing cable from the consumer unit earth bar to the main protective bonding on the training board. Is this ok?
I know there are a lot of questions here and please understand that I am in training and it's hard to get tutors to help you when you're not in the training centre. I would really appreciate guidance with this. I hope I'm on the right path with what I'm doing, and if not I am happy to learn.
