Plinth kitchen lights - need a plug. | on ElectriciansForums
Discuss Plinth kitchen lights - need a plug. in the Australia area at ElectriciansForums.net
A
alanl
Hello all, i've got to fit some under plinth kitchen lights this week. The 1.5mm T+E wiring was put in weeks ago at first fix, fed from a light switch on the wall.
We were expecting LV lighting, fed from 2 transformers, and have one or two junction boxes to wire in the 2 pairs of lights.
Now, when given the lights, they do have transformers, but it is a 'plug-in brick' type transformers (like phone chargers), so we have to re-arrange our thinking.
The idea we have now got is to fit a 2 gang 13A socket on the end of the cable,and plug the transformers directly into that.
The downside to that is that there will be a trailing socket under the kitchen units, connected to a 6A mcb.
Firstly, as the socket will not be accessible without removing the plinth, is this acceptable mechanically?
Secondly, again, if anyone does get it out, they could then plug in a hoover, and draw more than it is rated at. Our defence is that it is not readily accessable, and will be marked up "for lights only'.
Putting in a new cable is a no-go - it's a tiled floor now.
Any thoughts on how this could be done better?
Alan.
think as long as you label the socket/s as you have suggested , you should be ok. would like to see the socket/s fixed to something though.
The plug top on the transformer is moulded yes ?
Other than lobbing off the moulded plug and fitting a 5 amp socket theres not much more you could do with them
What I did was a piece of 3x2 with a socket on, wedged up and no nailed to the underside of one of the cupboards
The location of the socket may need to be correct because the string of lights needs to reach wherever
If someone wanted to plug a toaster in later on the 6 amp mcb would protect the cable
Why they would want to go to that trouble eludes me at the moment but,you are ok with a standard socket as long as its kept up out of the way of any flooding
Yes, it is a kit, bought by the customer. Never seen them before, power brick, with 4 led's attached to a long thin cable. No chance of cutting off the socket, as it is an integrated plug/transformer.
I'm going today, so will sort out a way of mounting the socket under the units to make them unaccessible unless you are really determined to stop anyone in future plugging in a kettle/hoover.
Alan.
For my LED plinth lights (sounds the same as your kit) I have a single socket on the wall under the plinth fed from the switch, via the under cabinet lights. I've just labeled it up properly.
Can't stand cabinet and plinth lights that run off a FCU above the worktop!
If they want a decent job doing here then get rid of the plug-in tranny's and get a couple of off the shelve TXs and mount as you had first planned. Some customers are their own worst enemies, they really are!!!
Reply to Plinth kitchen lights - need a plug. in the Australia area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
I guess my last post was even less direct than intended.
nicebutdim
N
