Plug socket, no power | on ElectriciansForums
Discuss Plug socket, no power in the Australia area at ElectriciansForums.net
A
Alexis27
I've moved in to a flat which is two years old and fitted a 3 holed plug socket onto the unused wiring behind the kitchen units in order to install a dishwasher.
Above the units is a switch and fuse.
There is no power though and a voltmeter comes back as there being no current.
All the circuit breakers are fine, I've checked the fuse and checked the wiring, but with no luck. Am I missing something obvious?
Getting in a qualified electrician to check it out properly before you get hurt.
Reply to Plug socket, no power in the Australia area at ElectriciansForums.net
Assuming you are a novice to electrics? As in no access to electrical equipment. Plug something in to the sockets that you know works else where...
Cbelectrics
C
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
