K
Kev63
Hi,
I've recently just bought a mid terrace house roughly built 1900 and the switches in the house seem bizarre. I've asked sellers why it's like this and they don't know the reason why it was setup this way. Everything is working fine however but after a few weeks now the switch system is starting to get annoying.
An example would be that for the ceiling lights switch to work (turn the ceiling light on and off) i have to make sure a fuse switch is turned on which is at ankle height on other side of room. Another example in the main bedroom the left side bedside lamp which plugs into a socket wont turn on unless the fuse switch, again close to the floor is turned on. It's really annoying in this case as the fuse switch is by the bedroom door, the other side of the room again. Makes the convienience of a bedside lamp redundant. It's strange in the sense that the left side lamp needs this but the right side works as you would expect and isn't affected.
I know I could just keep the fuse switches on at all times to get around this problem, but they emit an orange light and so I'm worried about power usage. I'm not sure if its safe to do this either as the fuse system must be in there for a reason. Does anyone know why the house is setup in this way and should i need to worry about anything?
