plug sockets | on ElectriciansForums
Discuss plug sockets in the UK Electrical Forum area at ElectriciansForums.net
V
viper8
Hello everyone
new on here ,so be nice
i have a large back outhouse at my property
that was used back in the day for a coal bunker/toilet .
this has all been removed now and made into a bedroom .the walls are solid and have all been plasterboarded .
there are 2 x light switches
but no plug sockets ( at the moment there is an extension lead plugged into a socket in the kitchen ) powering the room .
my question is ......................
how can i run a cable either from my fuse box in the living room or somewhere else .to power plug sockets in the new room ??
can i run the cable from the plug socket in the kitchen to power sockets ( or is that dangerous )
a detailed how to would be very helpfull
cable i need ,sockets ,etc etc
Take a cable from a socket in the living room, making sure you spur from the ring, and not spurring from a spur - then have a FCU and feed as many sockets as you want in the bedroom from the FCU in a radial format.
Livingroom socket - FCU - bedroom socket(s)
What's a plug socket, no on a serious note, Ans 1 with difficulty Ans 2 is it your kitchen or next door's? Ans 3 it would be very helpful Ans 4 electric cable/sockets
in 4 words:
get an electrician in
it will be installed properly, inspected & tested for conformance....you will also recieve relevent certification for works carried out...
this is an electricians forum....for electricians.
not a `drop in centre` for have a go hero`s and bored diyers
You want to turn it into habitable room yet you want to bypass having it installed and tested. You want to use it as a bedroom, sleeping risk. No mention of a smoke alarm which is a must in this case.
Pay some money, no offence but you need to, it pays in the long run.
Reply to plug sockets in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
