Plumber cut main bonding | on ElectriciansForums
Discuss Plumber cut main bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
Benny_Boy
Alright fellas,
Went out to wire in a boiler today and the plumber has cut the water main bonding:eek: to make "a bit of room"
nice
Can I make a joint and still comply? or do I have to run an unbroken cable?
I was thinking possibly a crimp?
any ideas?
Tell him he needs to pull in a new one ;) Doesn't a registered plumber also have the responsiblity of re instating earthing conductors as part of his remit.
No not really, besides have you got a 10mm through crimp and the facility to crimp it professionally?
How far back has the idiot cut it; can you pull any slack to within 600mm of the stop****?
Wow the swear filter is turned waaay up!:D
Try telling a blinking plumber that.
I think I'd better have a good look through the BRB, although from memory I seem to remember that a compression joint is ok. I was just hoping someone might have experienced something similar and come to a similar conclusion......or not.:rolleyes:
Hehe, I can crimp it alright, but I'm just thinking if I'd fail it on a periodic or not. To be honest if I saw a main 10mm bond with any kind of junction I'd probably tell the owner it needed to be replaced.
Hmmm, shame really, it's a good 10m of 10mm too. well it was before richard head cut the bleeder!
OK I reckon I'll be running a new bondd tomorrow, unless anyone else has a decent reg quotation to persuade me otherwise..............please!
Periodics
Bungalows
Plumber firm
Bonding
Cut
Shove up attic
Lots of them
When somebody mentions Plumbers I just start shaking my head
Irresponsible
Much higher valued than us
Much Higher paid
Crazy world hey
Periodics
Bungalows
Plumber firm
Bonding
Cut
Shove up attic
Lots of them
Irresponsible
Much Higher paid
Crazy world hey
You feeling OK Des?:D
I think you missed "Jumpers for goalposts"
No, not gone crazy yet. :)
They annoy me that much sometimes that I could write a book with the critisism. :rolleyes:
I wouldn't waste my time expanding conversation about them and what they get away and to then be rewarded so well for their "couldn't give a crap attitudes"
Not all of them mind,just the vast majority :)
I thought a crimp is classed as a permanet connection and then you can cover it with heat shrink?. Would like to know if this is acceptable
Crimp correctly with 10mm copper tube crimp, and tape up green/yellow. It's no different from crimping a lug on the end of bonding or any other conductor.
I have done thousands of these (I work for a heating firm - mainly installing bonding day in/day out). My large Knipex ratchet crimpers go up to 25mm. They stamp the number into the crimp, so any inspector can check that you have used the correct compression tool.
If I were to come across this on a PIR, I would inspect this termination the same as any other crimp connection: that the copper is to the end of the lug, the crimp is near the base of the lug, and the correct number is stamped into the crimp.
Every new bond I run, I am required to crimp a lug on the end for the bonding clamp (this makes for a professional job), then test continuity of the conductor using R2 Lead, label MET end of cable just before termination with permanent maker (gas, water, oil etc), and place a sticker by the MET "safety electrical connection do not remove", as it is separate from main switch gear.
Reply to Plumber cut main bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
Main 24HE constantly cutting out and firing back up on HW and Heating and intermittent flame failure light. I am having a problem with my main...
keyplayer
K
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
Recommended Sponsor News
Hi everyone,
