sedgy34
Have you had a plumber saying he cant pass the boiler cause the sparky hasnt cross bonded the boiler
Discuss Plumbers dictating earthing requirement in the UK Electrical Forum area at ElectriciansForums.net
its not a reg to cross bond the boiler its the plumbers who are told to do it as its in there gas regs but they dont want to do it if a sparky is around they like to pass it on so they dont have to do it
Would it not be the installers responsibility to ensure that the manufacturers instructions are met? Last couple of new builds I've done I've had nowt to do with the heating system other than to provide a spur for it. Everything else has been done by the installers.
With regards to gas boilers, how much is a non Gas Safe member allowed to do? Are sparkies permitted to start fitting external stats, timeclocks and the like?
Yes, they can.Would it not be the installers responsibility to ensure that the manufacturers instructions are met? Last couple of new builds I've done I've had nowt to do with the heating system other than to provide a spur for it. Everything else has been done by the installers.
It sounds like a case of "thats how its been done for years and we will continue to do it this way !!"
What about the ones with copper "tails" from boiler leading down to PVC pipework
Reply to Plumbers dictating earthing requirement in the UK Electrical Forum area at ElectriciansForums.net
