They really do themselves no favours sometimes!!
Just got back from a call-out, elderly woman, oil burner went out last night and the programmer was dead. So gets a plumber out this morning, has a look and decides it's an electrical issue but 'can't find' the incoming mains (took me about 2 mins to find, helps if you look in the right place...) and said to get a sparky in to sort out the timer.
I arrive, it's all dead, fair enough. Find the fsu buried in the most inaccesible of corner units with a 1" hole for the switch (please can I add kitchen fitters into this rant?) so 30 secs later there's a 4" one instead and I've changed the fuse, don't know if it's gone or not as drops out of the carrier down behind the back of the unit. Fit new one, get meter onto the terminals of the 6 plate, momentary life then dies.
Hmm, thinks me. Remove cover off boiler, disconnect the controller cable and fit a flying lead to a plug - pop goes the RCD. Open the other cover on the boiler to find lots of water everywhere and the pump is knackered in every sense. It's an oil burner sat on the floor with pushfit covers for petes sake, takes seconds to remove and refit, and he hadn't even bothered. He'd also turned his mobile off when I tried to call him to tell him to come back.
