plumbing in portable gas stove? plumbing advice | on ElectriciansForums
Discuss plumbing in portable gas stove? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
plumbing in portable gas stove? I'm moving to a flat currently fitted with an induction hob, but I really can't live without a wok burner. The best wok burner approved for domestic indoor use is a German propane-fed portable burner. I'm told the manufacturer can re-jet it for methane - but is there a compliant way to get a portable device permanently plumbed into the mains? If so, is it something any registered engineer should be happy to do?
(I have not yet found out whether the manufacturer has gone to the trouble of getting UKCA approval, which may kill off the idea anyway.)
plumbing in portable gas stove? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to plumbing in portable gas stove? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Capped gas pipe begging oven Hi all. Hope you are well. So I fitted a new induction hob today for my father and whilst the old hob was off I saw...
Steveuk
K
What do you think of this flexible gas hob connector? BES.co.uk | Next Day Delivery On 15,000 + Plumbing Supplies Order gas hob connectors and...
kasser
K
