We recently had an unvented cylinder installed (to replace an old vented one) and the higher pressure of the hot water has made us realise how crap the tap is on the kitchen sink. Had a wee look under the sink and discovered that I have no isolating valve on the hot pipe!
Would I be right in thinking that if I turned off the cold supply to the tank and then run the hot tap the water wouldn't come through?
