Plunger switch help please? | on ElectriciansForums
Discuss Plunger switch help please? in the Australia area at ElectriciansForums.net
P
Petel
Could anyone please advise as to the following?
Seeking a plunger switch ( car door sort of thing ) with a " momentary " function, to be fitted into a gate post, so that when the gate is opened a momentary signal is sent. Have been to all the usual sites and done all the usual searches, with no result.
There are plenty of NO/NC types ( and several which will do both ) but I am yet to find one with a momentary function.
If anyone knows of such a plunger switch being commercially available ( perhaps in a security system setup ) then would be most grateful to hear of it.
Many thanks, Petel
Many thanks to Toolguy and Spider for the replies.
The solutions offered would indeed do the job but are not quite what I am looking for.
If anyone is aware of an " off the shelf " spring loaded, plunger switch which would provide the function mentioned, would be most grateful to hear of it.
Thank you, Petel
Does it need to be a plunger switch?
Couldn't you get away with using the outdoor mag contacts the alarm boys use, and maybe a contactor? Depending on what you exactly have in mind, I'm not too sure from your post.
Just a thought
Jim
Reply to Plunger switch help please? in the Australia area at ElectriciansForums.net
