delindevon
Hi all,
I have just been to price a CU change. The problem is the CU is about 20m from the mains position and is run in 16mm T&E. Here's the good bit the 16mm runs through a neighbours flat, so it can not be replaced and I can not run an earth next to it. I can, though not easily, run another earth and a stake. If I do I think I should disconnect the PME, although I dont want to. What about a RCD to protect the 16mm if I fit one I can't seperate the circuits inside the flat and a RCD 20m away is not ideal.
Any ideas, thanks Del.
