A
Adrian Sadler
Hiya all
So on a pme system you can either use the earth from the cu and essentially export pme to the tub. Not against the regs afaik.
Or tt the tub.
Is there any tests that can be done (like the 23k ohms test) that will give a definite answer as to what method to use?
For the people who say rod it - what about the 13a plug in tubs? Nobody's gonna be rodding them. Plug and play....
Or tt the tub.
