huntos33
Is it common to attend a propery with a new PME cut out , to find the main earth still on a rod assume at some stage the supplys been changed ? do the dno not change this over ?
I'm guessing a quick phone call to the DNO will confirm supply ? is this something they should then change free of charge or do i remove fuse and undo the cover to the side and pop the earth in myself ?
