La Poste
Howdy folks.
I have been reading a thread on another forum about PME and lost neutrals and one of the comments was this:
Also:
IET Forums - "give PME the boot"
I can not see how losing a supply neutral would result in an over voltage.
Has any one got any ideas?
Thanks.
You may wish to give PME the boot but that will not save you from a fire due to over voltage caused by the loss of the supply neutral.
Also:
Going over to TT will not protect you from over voltage caused by the loss of the supply neutral. It could be the fires in these properties are due to over voltage causing damage to appliances setting them on fire.
Thanks.
