Polarity puzzle | on ElectriciansForums
Discuss Polarity puzzle in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Shay butler
I recently came a cross a piece of 3core swa brown black grey, that had been attatched to a piece of 2 core red black swa. I have confirmed that the brown conductor is attached to the red conductor and is indeed the line conductor. How can i determine which core, either black or grey has been used as neutral? The swa has been connected using a sealed compound joint so i cant see the connection. I only have access to the db supplying the 2 core swa to turn the mcb on or off.Hope this is clear enough for somebody to help!
Thanks guys
one way would be to connect it up with a RCD at the source . then when you plug in and switch on an appliance, if the RCD trips, N/E are reversed. ( defdinitely a don't try this at home ). the correct way would be to use a wander lead and " bell" the conductors.
Is it Fun-time Friday again already lol
Yep, if you don't have one then you can make one. I keep a roll of single core for the occasions where I need a wander lead;)
:thumbsup
I can check at load end. I can't check at the supply end. I know browns line because voltage between brown an black an brown an grey is 230v but between black an grey voltage is 0v
can you not access the supply end? short out the red/black at supply DB, then find out at the other end which colour has continuity with the red, then that is your neutral.
Well in theory if it was me who had installed, id of used the Grey as neutral and sleeved the black with green/yellow
However not everyone conforms to normal sparky life and make their own colours/rules up
Why cant you check at supply end? im presuming you know where the supply is, otherwise how will it be isolated? and how can you carry out the necessary testing/inspection?
same as happened in 2006. then it was the bureaucrats and the IEE making up the colours.
That is how I would do it also but I would have also sleeved the grey with blue to identify the neutral
That implies (to me) that the black & grey are connected at the joint.
Buzz the black & grey to check.
Otherwise, connect a lamp, or something, brown/black and brown/grey and see which way lights it up.
the lamp will light up on L/N and also on L/E, unless the cable is RCD protected, then if it's across L/E the RCD wil not like it and go home, taking his toys with him.
the lamp will light up on L/N and also on L/E :), unless the cable is RCD protected, then if it's across L/E the RCD wil not like it and go home, taking his toys with him.
See what you're saying there though, N/E connected through the supply. I'm assuming (ABTMOAFUa) that his 'spare' core isn't connected to earth at the joint, that it's either floating or connected to the other (Bl/Gy) at the sealed joint. If the spare core is earthed at the joint it makes it a bit more difficult! He needs to get that DB opened up!
Reply to Polarity puzzle in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
That makes sense. Thanks James.
