i thought interconnecting r1/rn on your ring was the only way to prove polarity on sockets before the circuit is energised ?
Simply turn the switch on and off. You have to use some common sense when testing.
If that way is incorrect how do you test for polarity?
Agreed but how would this reveal a L and E reversal
I remember watching a video showing something close...
Found it
Polarity - YouTube
I'am at college, never really done any testing and want to get a head start for when I need to learn them. I know I'm probably asking silly questions but I'm trying to learn!
Polarity is a live test
Is it?
A R1&R2 test can be used for this too.
That's what they told me on my 2391
It can actually be either a live or dead test.
Think about it, its common sense.When you operate the switch your meter will either show a very high reading or a very low reading. Would it make any difference to your readings if you swapped the leads over on your meter???
Visually check the device is correctly wired at the terminals. You can only visually see the terminals and not whats inbetween
So how do YOU test for polarity if you dont know the answer to your own question?
Well then if what is says in BS 7671, the OSG and GN 3 isnt good enoigh for you I suggest you wire all circiuts in singles in trunking pulling each core in individially. That is the only way you can 100% guarantee none of the things you point out actually occur.
Reply to the thread, titled "Polarity Test" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
