Poly poly questions | on ElectriciansForums
Discuss Poly poly questions in the UK Electrical Forum area at ElectriciansForums.net
Ireland
Helping a friend out with a gate/intercom setup. Some terminating and a couple of joints needed
Is there a decent stripping tool for this cable ?
What's the best type of connector for the enclosed joints ?
Cable has been in a while and is sticky as treacle ?
Sorry
10 core poly poly telephone type cable
The sheath is tough i'd need something to rip it
Also the joints I've to do, I remember seeing a simple crimped type connector used in telephone wiring
I've not heard of that type of cable but most telecoms cables I've seen come with some sort of rip cord inside it to split the sheath.
Could be UY2 connectors, also known as jelly crimps, used for joining small solid core cables
Ah thanks I think that's the one , how do ye remember all the names UY2 😁 , id have to google it everytime
Cable is below , I think maybe that name not used in UK
It has a hard sheath and no rip cord
  • [ElectriciansForums.net] Poly poly questions
I know what you mean now, that cable is hideous to strip, in the past I've ended up just chewing at it with cutters.
Is that the version which is also filled with some sort of sticky goo that gets everywhere?
Reply to Poly poly questions in the UK Electrical Forum area at ElectriciansForums.net
Bonding cables don't need to be insulated, other than for a short section at the end to identify them, and as long as they're 4mm2 or greater are...
Just to close this thread off -- the F Crimp Plug for CT167 above works for a stranded conductor RG11 A/U cable. Mounting is a bit of a pig as the...
