polyphase motor standstill condition | on ElectriciansForums
Discuss polyphase motor standstill condition in the Electrician Talk | All Countries area at ElectriciansForums.net
Bradford
can some body explain with a diagram the standstill conditions of a polyphase motor please hope some body can help this is driving me mad
When you say standstill do you mean locked rotor? If so current draw is usually based purely on the resistance / inductance of the rotor winding. So on start up the current drawn can be 6 to 8 times FLC.
This is the best way I can describe it. On start up resistance is the predominant element controlling the current, at run speed inductance takes over. The resistance is the same I’ve shown it smaller to represent it’s proportion of the current limiting.
Hope this helps
Hope this helps
thankyou very much tony you a star mate
Reply to polyphase motor standstill condition in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
