polystyrene new build | on ElectriciansForums
Discuss polystyrene new build in the UK Electrical Forum area at ElectriciansForums.net
cornwall
Has anyone had any experience of working on an ICF new build? A builder we do a lot of work for has started a new project and we're going to be starting first fix soon. it will be the first time ive seen it let alone worked with it. any help and advice will be appreciate
was asked to fit a builders supply and supply to a caravan at a site with this icf stuff. it is basically 'polystyrene' that is filled with concrete and is meant to be super energy efficient when cured. can do all sorts of shapes and designs with it. they use timber frames to hold it in place when poured etc... if they get the timber support or polystyrene wrong then it can collapse when poured.
seemed a lot of work to me for barely noticeable gain, its meant to be cheaper but only if you have a good team doing the work. i assume inside the walls will be dot and dabbed and you will run cables in capping? as you will likely find you arent allowed to go cutting into the polystyrene or concrete for fear of affecting the thermal qualities and such nonsense.
Reply to polystyrene new build in the UK Electrical Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
We’ve recently completed the first and second fix of a barn conversion that is off grid with solar PV, batteries and a back up generator. This...
