pond fault | on ElectriciansForums
Discuss pond fault in the Australia area at ElectriciansForums.net
B
bigboy
has anyone come across this before? called out to a pond fault where the fish were dying due to a voltage in the pond. 2 disboards in the house 1 for the house and 1 for the outside stuff, pond and lights ect. the voltage in the pond only happened when ethier of both disboards were switched on???
so to be clear the voltage was present even if the pond supplys and all other outside cables were dead !
No I've never come a cross this but the only thing common to the both supplies even when one is switched off is the Earth. Sounds to me you have an earth fault on one of the circuits. Are the fish fried I like mine battered,sorry
My other hat is a Koi Helatcare assistant so I get to play ponds a lot. A voltage in a pond is VERY common and its really important that a) all pond circuits are on RCD's and b) you earth the pond (you can buy Stainless earthing probes)
Pond liners, fibreglass etc are all insulators. It needs something to conect to earth to put the charge into the water (thats normally a person sticking their hand in). However small voltages over long periods do cause ulkceration on the fish
Stick your voltmeter positive in the pond and the negative in an earth socket and see what the PD is?
Normal cause of a PD is a flooded pump, or a leak in the UV unit
Check your L/N, L/E and N/E voltages and resistances and then repeat with the pump(s) out of the water. If the pump is flooded then it provides a path even when switched off (via neutral) all pumps are double insulated and many dont have earths. If its a hozelock titan, then you can pretty well be certain thats the problem
Would be suprosed if a high PD killed the fish though, Simple physics says the current flows around the outside of a conductor and a fish would be at the same PD over its whole length. Much mor elikely in this weather would be low O2 or high Ammonia/Nitrite
Reply to pond fault in the Australia area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
I misread it.
