M
madrid
I have to renew a faulty cable in a large pond at retirement complex.The cable in question comes from an output from a blagdon controller and passes some 15 metres along the bottom of the pond to feed another controller on the other side of the pond which in turn feeds 3 other items of pond equipment.firstly is it acceptable to run a feed through a pond and secondly if so what type of flex should I use to replace it.It currently has a 1.0 mm flex but I am unsure if there are special flexes for weather conditions and submersion .There are a number of similar flexes going into the pond from different outputs on both controllers,
